| Důležité upozornění |
https://translate.google.cz/#en/cs/CONCENTRIC%20SLAVE%20CYLINDER%20AIR%20BLEEDING%20PROCEDURE%0A1.%20After%20disconnecting%20a%20cap%20from%20the%20concentric%20slave%20cylinder%20air%20bleeder%2C%20insert%20a%20vinyl%20hose%20in%20the%20plug.%0A2.%20Loosening%20the%20plug%20screw%2C%20press%20and%20release%20the%20clutch%20pedal%20about%2010%20times.%0A%0AHold%20the%20air%20bleeder%20body%20not%20to%20rotate%20with%20a%20spanner(A).%20The%20holding%20is%20needed%20when%20the%20plug%20loosened%20or%0Atightened.%0A3.%20Tighten%20the%20plug%20during%20the%20clutch%20pedal%20pressed.%20Afterwards%2C%20raise%20the%20pedal%20with%20a%20hand.%0ATORQUE%20%3A%0A25~29Nm%20(250~290Kgf.cm%2C%2018.2~21.1lb-ft)%0A4.%20After%20pressing%20the%20clutch%20pedal%203%20times%20more%2C%20loosen%20the%20plug%20and%20retighten%20it%20with%20the%20pedal%20pressed.%20Raise%20it%20again%2C%20then.%0A5.%20Repeat%20the%20step%204%20two%20or%20three%20times.%20(until%20there%20is%20no%20bubble%20in%20the%20fluid)%0A%0A1)%20Do%20not%20clamp%20the%20pipe%20of%20a%20concentric%20slave%20cylinder.%0A2)%20Be%20careful%20not%20to%20damage%20O-rings.
stadt píše:mne menili spojku pred 3rokmi a dnes som bol v servise menili mi štarter lebo pri nastartovani 1krat len cukol az potom nastartoval a mi servisak povedal ze mam zlu spojku lebo mi zabiera na podlahe ,,som mu povedal ze ju nemam ani tri roky niekedy mi ide v pohode radit jednim prstom ani sa nemusim dotykat paky a inokedy mi to ide celou rukou
